E30 M3 Prop UJ's
Andy325i
Post Mon Aug 29, 2005 12:08 pm
Anyone know if these can be replaced or is it a throw it away job? :cry:
Andy
M3Compact
Post Mon Aug 29, 2005 12:19 pm
Mega difficult to replace, but can be done.
Andy325i
Post Mon Aug 29, 2005 12:22 pm
Hi Simon, do you know anyone that can do it, and what sort of price?
There is a place locally but being a bank holiday are shut :banghead:
Andy
M3Compact
Post Mon Aug 29, 2005 12:25 pm
Andy325i wrote:Hi Simon, do you know anyone that can do it, and what sort of price?
Andy
The only place I know is in Leeds, they're official 'Hardy Spicer' agents and you have to twist their arm to do it, with no guarantee of success.
Andy325i
Post Mon Aug 29, 2005 1:47 pm
Cheers mate, may be worth a shot
Andy
madbeemer
Post Mon Aug 29, 2005 1:51 pm
hi there andy, what with the ETA for sale for Ԛ£50?? :?
dazleeds
old skool raver
old skool raver
Post Mon Aug 29, 2005 1:52 pm
whats this about eta for Ԛ£50???
www.oldskoolfantasy.co.uk
madbeemer
Post Mon Aug 29, 2005 1:59 pm
on andy's 325 picture, it say's 2.7 eta for sale. Ԛ£50 just wondered what that meant?
dazleeds
old skool raver
old skool raver
Post Mon Aug 29, 2005 2:01 pm
me too????
crank? engine? full car???
Andy325i
Post Mon Aug 29, 2005 3:05 pm
Basically it was a engine I picked up a while ago to do a 2.7 converstion on my 2.5, in the meantime I picked up an M52 so no longer have any use for it. Have heard it running, cam is noisy on it but this is irrelivent as its only the bottom end (crank/rods/block etc) that you want for the conversion.
Andy
madbeemer
Post Mon Aug 29, 2005 3:13 pm
so what parts do you have, and what engine are they actually from??? am interested.. tell em more please.. :P
Widge
Post Mon Aug 29, 2005 3:30 pm
Dunning and Fairbank in Leeds HERE! Did a custom prop for my kit car for Ԛ£80.
M3Compact
Post Mon Aug 29, 2005 3:40 pm
Widge wrote:Dunning and Fairbank in Leeds HERE! Did a custom prop for my kit car for Ԛ£80.
They're the HS agents I meant Widge, they don't like doing the non-clipped UJs.
They tried to get a clipped UJ joint for my prop from the USA but finished up using a Cosworth rear flange and adaptor, that fouled my beam and I ended up modifying the beam. :x
Right cock up for 8 weeks and Ԛ£160, plus loads of hassle. :-x
Widge
Post Mon Aug 29, 2005 4:14 pm
Thats ugly as! But good solid looking welds - will look jolly good when painted. They were the only people I could think of so I suppose they are worth a try, I always recon that if they don't do it they will know who does!
M3Compact
Post Mon Aug 29, 2005 4:27 pm
Widge wrote:Thats ugly as! But good solid looking welds - will look jolly good when painted. They were the only people I could think of so I suppose they are worth a try, I always recon that if they don't do it they will know who does!
They were really stumped with mine Widge, I wanted some kind of sliding arrangement in the rear to avoid loading up the box or diff with any engine movement. (E36 M3 prop, with rear CV joint and solid centre joint.)
Andy Fairbank dropped a wagon prop on his foot and disappeared off sick with all my dimensions. :-x
Mel sorted it eventually with the cossie flange and adaptor, but then it fouled the beam. :cry: The whole thing took 8 weeks to sort and the full story reads like a Laurel & Hardy script.
All because they were scared of the non-clipped UJ. :(
Widge
Post Mon Aug 29, 2005 4:57 pm
What exactly is the differance between a clipped and noon clipped UJ? Presumibly it is the circlips that hold the pivots in?
M3Compact
Post Mon Aug 29, 2005 5:03 pm
Widge wrote:What exactly is the differance between a clipped and noon clipped UJ? Presumibly it is the circlips that hold the pivots in?
Yes, apparently some BMWs have the circlip type joints, D&F couldn't find one to use with the E30 M3 diff.
Andy325i
Post Mon Aug 29, 2005 9:52 pm
M3Compact wrote: I wanted some kind of sliding arrangement in the rear to avoid loading up the box or diff with any engine movement. (E36 M3 prop, with rear CV joint and solid centre joint.)
How does this work mate? Would it benifit me much?
Andy
M3Compact
Post Mon Aug 29, 2005 10:06 pm
Andy
E30s have a sliding joint in the middle, that doesn't lock 'shock' tight, so you don't need one.
My prop had a solid middle joint, with a sliding CV joint on the rear, but the rear flange needed swapping for an E30 solid flange.
The HS agents could adapt the E30 M3 rear flange to slide, but the non-clipped joint scared them off, and a clipped joint BMW flange couldn't be found easily. (Hence the Cosworth rear flange with adaptor, that fouled the beam. :-x :x :cry: )
In theory, there's no need for a sliding joint on a car with a bolted up diff, as opposed to a 'live' axle, but any engine movement causes loading on the prop ends. (G'box output shaft/diff pinion input flange) I didn't want this possibility.
