HELP! 320i Rear drum to disk conversion
MacGTR
Mon Feb 22, 2010 1:15 pm
Hello chaps. I could do with some more braking power, so I seriously need to get shot of the drums at the rear and swap to disks!
I have an '88 320i, what parts do I need? Or even better, if anyone has already done a step by step guide. If not I will probably do one as this must be common.
sihooker
Mon Feb 22, 2010 1:38 pm
MacGTR
Mon Feb 22, 2010 1:45 pm
Excellent!
Thanks :D
sihooker
Mon Feb 22, 2010 1:50 pm
No problem. If you get stuck, there'll always be plenty of help available on the zone :D
MacGTR
Mon Feb 22, 2010 3:26 pm
Mhmm, So, considering I am changing to brembo discs and Pagid RS29 pads. I need what parts?
I am still a bit shady...Its a pain because I am a hundred miles away from the car most of the time, so I can't take it apart and have a look hence the questions... :roll:
rix313
Mon Feb 22, 2010 4:00 pm
IMO I wouldn’t expect miracles when you fit the rear discs. Of course the extra brakes will help but from general experience the do next to naff all most of the time.
What do you mean what parts do you need? So long as you buy standard fitment discs and pads you don't need anything else.
sihooker
Mon Feb 22, 2010 4:28 pm
The list of parts you need are in the link...
MacGTR
Mon Feb 22, 2010 6:12 pm
I have drums on the rear at the minute. I mean, I can't just remove the drums and stick on calipers, discs. Or can I? I didn't think the drum rear trailing arms had caliper mounts? As I said before, I am away from the car a lot so its hard to just go have a look.
And the car is being used in the PBMWC so its just something I want to do for lower temps and less brake fade.
Mon Feb 22, 2010 6:16 pm
you need the rear disk trailing arms to replace the drum trailing arms
they can be got from any tourer, cabriolet, all 325i's and 318IS have them fitted as standard
