alloys different stud patern
garymillscab
Post Tue Aug 23, 2005 3:24 pm
can you buy anything to convert alloyus that are ment to fit ford four stud to my 4 stud
Jos
Post Tue Aug 23, 2005 5:29 pm
http://www.tunershop.co.uk/
do 4 to 4 conversion plates, ford are 4 x 108 ET35-38 63.3 Centre bore
BMW are 4 x 100 ET15-25 57.1mm Centre bore
There are 3 sets that go from 108 to 100: ET-20, ET-25 and ET-30 so you need to keep your ET offset in mind, you should be ok as Ford are ET35 to ET38 and the e30 is ET15 to ET25 so an ET-20 on an ET35 alloy will give you ET15. The only other thing you need is a spigot to match the new centrebore.
the next question is why you want Ford alloys on....
'94 e36 tree climber
A1BMW325iSport
Post Tue Aug 23, 2005 6:51 pm
cool which ones do i need to fit 5 stud bmw alloys?
garymillscab
Post Tue Aug 23, 2005 10:57 pm
iv got lenso dtm but one cracked and lenso have stoped making them so gota take what i can.
which adaptor would be right for me sorry dont no much
A1BMW325iSport
Post Wed Aug 24, 2005 12:13 am
can you post a pic up of the lenso as i think they are the ones i`m after
garymillscab
Post Wed Aug 24, 2005 9:32 am
they are lenso dtm mesh alloys there bbs reps i think m8
Jos
Post Wed Aug 24, 2005 9:03 pm
Extreme Uber URL
If the link don't work then you need to select Adaption Spacers, select 4 to 4 and it's the 3rd one up from the bottom.
I think is the ones you would need assuming as they are off a Ford they are 108x4 PCD
garymillscab
Post Wed Aug 24, 2005 9:33 pm
cheers mate!!!
E30cabrioman
Post Thu Aug 25, 2005 2:50 am
Model P.C.D. Offset C/Bore
MINI (new) 4 x 100 35 57.0
3 series (E30) 4 x 100 15...25 57.0
3 series (E30) M models 5 x 120 18...20 72.5
3 series (E36, E46), Z3 5 x 120 35...42 72.5
5 & 7 series (E31, E32, E34, E38) 5 x 120 18...20 72.5
5 series (E39) 5 x 120 18...20 74.0
325i Cab
E39 V8
ian332isport
Post Thu Aug 25, 2005 3:10 am
I think you would be pushing you're luck a bit with an ET15 on an E30.
ET20 is about as far as you can go without sticking out past the wheel arch.
Ian.
