possible valve problem, worst case senario piston ring
spinner100
hi all have just had a bit of bad news, car was smoking a little to much for my likeing so took it down the garage as they have just serviced it, new plugs etc, they told me that cylinder 3 was a bit cloged up and that they thought it might just be because it had not had a service in a while,so they took out the new plugs to check them and sure enough number three was clogged up, they seem quite confident it is a valve, the smoke is white not blue and it smells a bit of fuel, has any one ever experianced this problem because i am looking at alot of money to get the head of to verify the valve problem.and if it is a piston ring it might be worth getting a new lump...........any replies much appriciated
sihooker
Have you had a compression test done?
spinner100
just spoke to my mechanic and he said he has done it and they are all around 6 to 7 bar, he said that it is all pointing towards a valve, cheers dude .ps is there any more photos of your car on here looks nice would like to see some more.
sihooker
Well at least it's only a top end job to replace a valve...
Regarding my car...thanks.
There aren't any more pics of her on here yet, but to be honest, it's a very normal looking 4 door in Lachs(salmon)silver.
spinner100
do you know if there is any way the valve could be stuck closed and maybe it might need to be cleared or adjusted, just a thought trying to save the pennys.................
sihooker
I dont think it's possible for the valve to remain open without it hitting the cylinder. As for the valve staying closed...that could only happen if the rocker is bent or broken.
spinner100
yeh i think im just clutching at straws i dont think there is any cheap way round this.
spinner100
what does that involve............?
