si board batterys
spinner100
Mon Jan 11, 2010 5:16 pm
hi all does any one know where i can get a good price on a si board battrys as my instrument cluster is playing up and i have been told this is more or likely the problem.my local bmw dealer wants to charge me £185 for this part it just seems a little steep. any replies would be much appriciated........
Mon Jan 11, 2010 6:51 pm
CPC/Farnell, RS components.
spinner100
Mon Jan 11, 2010 6:56 pm
thanks you must be getting bored of answering my questions............ :D
George
Fri Jan 22, 2010 10:41 am
What is the 'spec' on the battery, to ensure I order the correct one?
Fri Jan 22, 2010 6:56 pm
Depends whether you need Lithium or NiCd ones.
spinner100
Fri Jan 22, 2010 7:00 pm
Managed to get a complete board with batterys but now the speedo works but not the rev counter
George
Fri Jan 22, 2010 7:27 pm
Brianmoooore wrote:Depends whether you need Lithium or NiCd ones.
How would I know? :o:
Chris-W
Fri Jan 22, 2010 7:28 pm
Open it up and have a look. They have it written on them.
George
Fri Jan 22, 2010 7:29 pm
I will look tomorrow. Are they typical AAs?
Chris-W
Fri Jan 22, 2010 7:31 pm
Nickel Cadmium are the usual AA size, Lithium jobbies are 'stubby' to give them their technical name.
spinner100
Fri Jan 22, 2010 7:33 pm
no they are funny little 3 v batterys in my opinion mate you would be better to get a new board as the batterys are soldered in and are covered with a rubber silocone so are very hard to get out. i got my board for 40 pound. i still have problems though........... :mad:
George
Fri Jan 22, 2010 7:35 pm
Chris-W wrote:Nickel Cadmium are the usual AA size, Lithium jobbies are 'stubby' to give them their technical name.
Is there a year where the change occurred?
spinner100
Fri Jan 22, 2010 7:37 pm
what year is yours mine is 89 and has the stubbys.
Chris-W
Fri Jan 22, 2010 7:40 pm
Honestly not sure, sorry.
Chances (odds on) are that if they've failed you have the earlier type. All that I come across that have failed are the earlier type, earlier cars with still functioning clusters most usually have the replacement type later board (discernible by a storage jumper, no, not knitwear).
George
Fri Jan 22, 2010 7:41 pm
spinner100 wrote:what year is yours mine is 89 and has the stubbys.
86, so I'm assuming 'stubbies' as well? Where can these be bought from?
spinner100
its really easy to get your instrument cluster out and to remove the si board from it and check them.
George
Fri Jan 22, 2010 7:45 pm
So it is possible to 'upgrade' the earlier type to the later type?
Chris-W
Fri Jan 22, 2010 7:55 pm
George wrote:
Chris-W wrote:
George wrote: Is there a year where the change occurred?
Later type, here I mean single red SI light boards, are a straight swap, yes. I.e. Nicad to Lithium. Hope that makes sense.
Fri Jan 22, 2010 9:48 pm
The earlier boards had NiCd batteries, and the later version used lithium cells, BUT it's very unlikely that many E30s are still on the original NiCd batteries, and most will have been replaced at least once by BMW.
The replacements may have been lithium powered boards or rebuilt NiCd boards, depending on what was in stock at the time, so there is no way of telling what any particular E30 has in it without looking.
Most of the odd problems are caused by boards with the NiCd batteries, not by them losing charge, but by their habit of becoming short circuit when they fail, and 'loading' the power supply for the other instruments.
The main problem I have seen with clusters fitted with lithium batteries is a fairly trivial one of the tacho needle jumping up to several hundred revs when the engine is off, but, since the lithium batteries are not rechargeable, if a cluster with one of these boards is stored for a length of time (years), without the board being switched off, the batteries will permanently fail.
Polanskygreg1985
Sun Jan 24, 2010 12:30 am
it's really not that easy, in fact, its a pain in the ass. I gotta replace mine as well, but im not sure which ones to get, would these work? http://www.batteriesinaflash.com/bmz_ca ... 00x240.jpg
Sun Jan 24, 2010 9:54 am
Like most jobs on an E30, if you find it difficult, you're doing something wrong!
What particular part do you find is "a pain in the ass"?
Which batteries you need will depend on what version of the board you have, but whichever they are, they will need to be the type with solder tags fitted.
