Cold Weather
b4gga83
Hi all
This problem has only started since the winter weather has kicked in.
When I start the car after a prolonged period of sitting still the car starts but as soon as I let go of the accelerator it will drop below idle and stall.
I have noticed that it is also 'kangarooing' more than usual too.
Any advice?
Any advice?
TPS
What car is it?
b4gga83
Sorry its a 325 with auto box.
stonesie
Do the usual checks for air leaks first on the rubber bellows, the old rubber could have got that little bit harder in the cold and cracked.
It could also be somthing to do with the CTS, Coolant temperature sensor.
What engine is it?
What engine is it?
TPS
Also might be worth cleaning the throttle housing & ICV with carb.cleaner.
b4gga83
Saying that stonesie the coolant light came on for the first time on the check panel this morning, could that have anything to do with the CTS?
I have had the 90 degree rubber boot changed as that was split, what others should I be checking?
The plugs, leads, dizzy and rotor arm had been replaced in the summer of this year.
b4gga83
The revs aren't bouncing either.TPS wrote:Also might be worth cleaning the throttle housing & ICV with carb.cleaner.
Is it still worthwhile cleaning them?
TPS
Its worth doing that, its a simple job, will need doing at some point anyway, My idle was all over the place & that sorted it for me.
b4gga83
Excuse me for being thick, but is the CTS also known as the blue temp sensor?
TPS
Yeh, the brown one next to it is for the temp.guage.
b4gga83
Thanks - if this sensor is khaput, will it cause the 'kangarooing' whilst sitting in traffic irrespective of whether its in gear or not?
TPS
It could do, the C192 plug might need cleaning, I think this controls the signal to that sensor. Reading threads on this subject, it appears that could often be the cause
b4gga83
Right I'm on the realoem website looking for a CTS and C192 plug - could anyone point me in the right direction?
TPS - I'm looking in your direction
TPS
The C192 plug is located underneath the Inlet Manifold, the wiring comes from the injectors into a connector(C192), unscrew the connector, normally water gets in there, spray WD40 & Contact Cleaner. If your unsure just use the search function for "C192"
asmith88
have you tried testing it with a multimeter?
1990 brilliant red 318 is
