hi there guys.... simple enough query but need some advice......
my fan heater is dead on position 1,2,3 but 4 is fine....this MUST be the rotary switch right???? or cud it be a lose wire?
fan heating issues...
- breezebreeze30
gareth
not had the problem myself but i believe it's common and to do with the resistor pack, not the switch.
braxtonator
Sort out the sig and your hardtop pleasebreezebreeze30 wrote:hi there guys.... simple enough query but need some advice......
- breezebreeze30
Until you have somthing worth showin work on putting ur money where ur mouth is u phen da phuda!
Garath so can i just change that whole unit?behind the dial?
braxtonator
Money where my mouth is?breezebreeze30 wrote:Until you have somthing worth showin work on putting ur money where ur mouth is u phen the phuda!
im hardly gonna come to ur house change your sig and spray ur hardtop am i
- Brianmoooore
You would imagine that it's fairly simple, will. If there's any hint of a technical question in the original post, then it should be posted in 'tech help', but there are plenty on here who don't seem able to work that one out!!
- breezebreeze30
cheers lads......the feedback was much appriciated.
- Brianmoooore
Bear in mind that if your fan motor is becoming stiff, through lack of lubrication, it will draw excess current, and your new resistor pack may not have the length of life that BMW intended.
