f reg cab
helmi25cab
Post Tue Oct 13, 2009 2:43 pm
hi every one my car has been parked up 4 last few weeks now got in today and moved it from were it was parked then noticed that water on the road, on pasenger side then looked under the car i can see water dripping from the sill so i opened the boot to see if its collecting water in the boot but its born dry does any one has an idea were the water is collecting from or how to sort it any help will be apriciated thanks!!!!!
beemerbird
Post Tue Oct 13, 2009 3:06 pm
Drainage pipes from the sunroof area travel through the boot compartment, allowing the water to drain onto the road. It may be that the camber of road that you were on caused a build - up of water in this pipe, which only became 'dislodged' when you moved it......
Post Tue Oct 13, 2009 3:21 pm
Doesn't have a sunroof Fi :wink:
The explantion is well put though :)
Did any water come out the drivers side sill?
helmi25cab
Post Tue Oct 13, 2009 3:24 pm
mate my car is cabriolet!!!
helmi25cab
Post Tue Oct 13, 2009 3:28 pm
no water from driver side sill fella!!!
beemerbird
Ooops. Just seen the error of my ways. Have just awarded myself tw*t of the day prize.
Post Tue Oct 13, 2009 3:41 pm
It's ok Fi :wink:
It works in a similar way anyway, in the hood compartment there are drainage holes on either side at the bottom (near the rear window). When water collects here, providing the holes are not blocked, the water drains out through the sill underneath the doors.
Sounds to me like, it's all normal :)
beemerbird
Post Tue Oct 13, 2009 3:44 pm
ImysE30 wrote: Sounds to me like, it's all normal :)
...and that my camber / movement theory could hold some water (no pun intended). TBH, so long as there is no water IN the car, I really wouldn't worry. Has it been raining recently, OP?
helmi25cab
Post Wed Oct 14, 2009 8:19 pm
Got in the cabriolet this morning noticed the pasenger side floor was wet, and the glove full of water. noticed as i was driving along water was comin in trough the foot well were the speaker is, how does the water getting in looked under the wheel archies cant see ant sign of rust or holes for the water to come inside the car, or i my looking at the wrong place? yes mate it has been rainning in suny brighton!!! last night, early morning!!!
Post Wed Oct 14, 2009 8:30 pm
Sounds like you have got a leak in the bulkhead/scuttle area? Check here for any holes
