tappety noise from 325i?
glenbat
Post Thu Aug 11, 2005 8:38 am
my new cabs tapping a little and been told one of 3 things, so thought id check it out with you lot. Firstly the tappets (or eccentrics) could need adjusting, i seen the link for this so will be doing this soon.
Secondly, could be blowing exhaust manifold, been told sometimes these crack is this right?
And finally, a lad down the local grage said something about injectors? Can anyone enlighten me are these common M20 probs?
cheers
glen
TOURINGDADDY
Post Thu Aug 11, 2005 8:45 am
alright mate firstly the noise if a rattle sort of noise tappets if a tick noise then exhaust or in let gasket as 4 the injectors they do alyays make a noise but u eould only heare this if the rest of the lump is sweet. so start with the cheepest if u can do ya tappets yr self i'd start there. :D
glenbat
Post Thu Aug 11, 2005 9:18 am
cheers touring..
would you replace the eccentrics too? Think theyre about Ԛ£2ish each?
TOURINGDADDY
Post Thu Aug 11, 2005 9:19 am
only if there worn
glenbat
Post Fri Aug 26, 2005 10:31 am
would they be visably worn, or only be able to tell once I've tried adjusting them?
cheers again
tourer-dan
Post Fri Aug 26, 2005 11:06 pm
With the engine cold, stick your finger in the oil filler hole and feel a cam lobe to see if it's got ridges worn at either side. Very common on cars which have just been bought, as the owner has taken it to have the tappets done (cheap) to be told the camshaft is worn out and needs replacing (expensive), so they sell it telling the new owner it only costs Ԛ£20 to have the tappets adjusted.......
Of course it might just need the tappets adjusting.
I've got a set of injectors if it turns out to be them and you want some, but they are usually very reliable (so I'm told)
let us know how you get on.
glenbat
Post Sat Aug 27, 2005 7:52 pm
dan
you a bit of an expert? im looking to borrow someone for half hour to give her the once over
glen
tourer-dan
Post Sun Aug 28, 2005 10:43 am
God no!!!
I've done a couple of Head gaskets on the M20 and know a bit about how they wear their cams. I did my own and reconditioned my own cylinder head.
Just learnt through experience and trial and error.
I'm perfectly capable of looking after my own car and would gladly help with any jobs if I can find the time, but I'm no expert!
glenbat
Post Mon Aug 29, 2005 1:41 pm
cheers dan
do you know of anyone local who is a bit of a BM nut? I was hoping to drive to someone in the know and them be able to tell if its eccentrics/cam wear/exhaust blowing just by listening or feeling? :oops:
glen
tourer-dan
Post Mon Aug 29, 2005 2:35 pm
I'm sure there'll be someone in Harlow, but if you get stuck and you're down this way give me a shout.
