Lip Spoiler clips.
orkboss
How do you remove the clips from the front valance that hold on the lip spoiler or whatever you call it. I cant see properly if I can squeeze the plastic rivet to remove them. Is it a case of extreme force and hope it doesn't snap?
smithy318i
use a screwdriver and a hammer to tap the pins through the retaining clip (upward). don't hit it too hard or you will loose the pins somewhere on the ground and never find them again.
orkboss
ah so they are pins and not a one piece unit. Thanks for the advice.
