Trying to help out another zoner here
Fitted another engine and gearbox, engine turns freely by hand but the starter motor just makes the clicking noise
starter was tested and was ok
what two pins do you link to try to turn the starter over?
cheers
bad earth/starter motor
spook
- League two here we come !!!
Make sure you have BOTH the 13mm terminals connected. Theres a black and a red.
To test it its the 10mm terminal below the 13mm terminal bridged with the 13mm terminal. I know cio we were doing this last night!
But make sure you have both the big wires attached at the same point.
spook
Cheers Trev, im on about the two pins in the round thing, cant remember what its called
Solenoid. Bridge the 10mm with the main 13mm where the 2 big main cables attached. That will kick the starter into action
spook
Trev, the round thing where you plug the inspection tool
We will try the above tip as well of course
the one in the Diagnostic plug ? I think it's pin 11 but double check I am no sparky !spook wrote:Trev, the round thing where you plug the inspection tool![]()
spook
Thats the thing, a Diagnostic plug
two pins, ive done it before but my Alzheimer's is getting me down
