now for all ye smart arses 500ccs wont do
a lad is trying to sell me a "sport" cheapo. says its down as a 320 on the log book but that it has a 2.5
what chassis no identifies a sport/325
looking at the engine is there an easy way to know the difference
thanx all!
difference between 320 lump and 325
oil cooler is 1 sign look at front behind valancecheck ecu under panal above ya knees
if its a 325 it should be 173 320 is 172 hth Daz
www.oldskoolfantasy.co.uk
yes the oil cooler is a good sign, you might want to check the ecu part number and the AFM part number. Or find the VIN number and go to this site and follow the instructions
http://www.realoem.com/bmw/select.do
good luck
good luck
rickk
- Contact:
Except from the oil cooler and ECU, think the easiest way to spot it is the injectors, 325i ones are grey/blueish, 320i items are yellow.
325i block also has a bigger intake system (everything, basically), but this is hard to spot if you can't compare directly. (then it's suddenly pretty obvious)
I figure he has dumped a 325i block in a 320i, if you want to check, the 325i 'shell' should have rear disc brakes (320i too if it's got ABS, but that's rather rare) and the battery in the trunk as opposed to in the engine compartment.
325i also has an anti roll bar at the rear.
Ofcourse, there's also a fair difference in performance
