Right, I'll probably need to replace the front pads on the Alpina in the next few months. It has the larger Alpina brake upgrade.
However, I presume Alpina would charge a left nad for the privilege of selling me a set (if they're still available?) but I've read a few times elsewhere that the Merc 2.3 16 190E cosworth / W124 300D pads fit - but with 2mm shaved off.
Has anyone else got any other info on this?
Ta.
Alpina C2 / B3 brake pad options - 296mm x 25mm
the calipers are W124 300E/190E cosworth. Not 300D!
Pagid,ferrodo seem to be the main companys for them. I've got a set of pagid road pads, and ferrodo DS2500 for track work on my setup.
No shaving required they fit straight on out the box
That's great Simon, thanks for the advice, I thought it was weird that the diesel would have the same calipers / pads as the 190E cosworth alright!
Where did you happen to buy your pads? Do you have a rough price?
Thanks again
Thanks again
GSF for the pagids stock road pad £28
bmw want around £160!
the ferrodo DS2500 where from europerformance.co.uk for around £100 posted in the UK. - These need heat to work they are crap from cold
- bigbhpwannabe
i take it that these dont just bolt onto normal e30 hubs or everyone would be doin cheap brake upgrades ? garySimon13 wrote:the calipers are W124 300E/190E cosworth. Not 300D!
325i 4door turbo sleeper -
big turb
e36 carbonfibre wietech strutbrace for sale . 07919173179
big turb
- bigbhpwannabe
im gonna try , my project started the other day so could beDanThe wrote:You need a nice adaptor plate Gary![]()
Will you be at Santa pod this year?
are u gonna come ?
big turb
big turb
correct you need the custom caliper carrier. As its a girling setup its a cast job like the calipers so looks factory. Not something which could be replicated easily, i've looked into that in the past
