What is this button...
classictwiggy
...in front of the drivers side electric window buttons.
When pressed it shows red around the edge and pops up. Has no markings on.
- E30 Zone Meets/Events Team
I take it you have 4 electric windows??????
It is a kill switch for the rear windows, if it doesn't work, pull it out, maybe its bee disconnected below.
HTH's
HTH's
classictwiggy
No, just the front two are electric, rear are winders.
Its a factory button so I assume it has a purpose.
Sport button? :p
Sport button? :p
pac1982
I have one of these as said above its simply to a cut of button for the window buttons once pressed it should stop your windows from working
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
George_Of_The_Jungle
i seem to remember brianmoooooooooooooore saying its a tripping/reset-able fuse
pac1982
No as above its a lock for the leccy windows i have the same button and it does just what i said
classictwiggy
Ah excellent, thanks guys. Thats fulfilled my curiosity!
It's not a lock, neither is it a switch. It's a resettable cut out, and should be left alone, unless it's tripped!pac1982 wrote:No as above its a lock for the leccy windows i have the same button and it does just what i said
ivqii
- Regression is the way forward !
lol it was sooooooo embarrasing
- pulled into my garage and told the mech dunno what's happened but both windows not working - he pressed the switch back in
As I get older I realize that you can't please everyone - pissing everybody off is however a piece of cake
pac1982
Either way when I press it my windows are locked so even though u may be correct I still class it as some kind of window lockBrianmoooore wrote:It's not a lock, neither is it a switch. It's a resettable cut out, and should be left alone, unless it's tripped!pac1982 wrote:No as above its a lock for the leccy windows i have the same button and it does just what i said
Your windows are 'locked' anyway, when the doors are closed and the ignition off. Why would you want a secondary 'lock'?
If you continually operate the 'switch', you will damage it, and it will fail to hold on. It just isn't designed for continuous operation.
Learn something new everyday
madaboutthe30
brianmoore, what do you mean unless the window has tripped?
Dreaming of the day I purchase an E30 M3
--- e30 motorsport cab-- in the process of becoming a trailer queen
--- Z4M Coupe - daily driver
pac1982
I know what u mean and ur knowledge of E30's is not to be argued with, I never use mine but the few times I have was to stop my passenger from opening the windowBrianmoooore wrote:Your windows are 'locked' anyway, when the doors are closed and the ignition off. Why would you want a secondary 'lock'?
surely the passenger can reach the button. or, you could suggest they dont use the window........ hmmmmm the possibilities
aj_mckay
...and escaping!!!pac1982 wrote:...I never use mine but the few times I have was to stop my passenger from opening the window...
pac1982
You got it in oneaj_mckay wrote:...and escaping!!!pac1982 wrote:...I never use mine but the few times I have was to stop my passenger from opening the window...
When the button has popped up on its own, so that the red band is showing.madaboutthe30 wrote:brianmoore, what do you mean unless the window has tripped?
kman82
oh thats what it is. The night i bought the car i pressed it and it popped up stopping the windows from working AND the stereo IIRC. never touched it since
SGP
Silly me ! I thought it was a button for the dad to press when he didn't want the kids playing with the leccy windows.
If it ain't broke..
Fix it till it is
Fix it till it is
