325i Relays
pimp_mobile
Mon Jun 22, 2009 1:59 pm
What does the blue relay do that is situated with the DME (White) and Fuel Pump (orange) relays? On mine these three sit in a black box attached to the passenger side bulk head.
e301988325i
Mon Jun 22, 2009 7:40 pm
Lambda sensor heater element relay
I said:
e30topless said:
lock the wife in there
pimp_mobile
Tue Jun 23, 2009 2:12 pm
Cheers.
Will it have a lambda sensor if it doesn't have a cat?
Tue Jun 23, 2009 2:29 pm
Only if it's been modified to run on LPG.
pimp_mobile
Tue Jun 23, 2009 6:17 pm
Hmmm... so what does the middle relay do then as it hasn't been modfied and it doesn't have a Cat and never has done. There are wires coming out the bottom of the socket so its connected to something(!)
Apologies I thought I'd put a date for my car... its 1990-91 (H reg)
yeah_mick
Tue Jun 23, 2009 6:42 pm
sorry for the hijack but comeing out of my relay box i have a long green wire thats been cut, ive tried running the car with them cut adn with them joined and it makes no difference to how it runs. any ideas on what that could be?
Tue Jun 23, 2009 10:50 pm
yeah_mick wrote:sorry for the hijack but comeing out of my relay box i have a long green wire thats been cut, ive tried running the car with them cut adn with them joined and it makes no difference to how it runs. any ideas on what that could be?
Shouldn't be any plain green wires going to the box with the three relays. Plain green is unfused ignition switched live, and doesn't go anywhere near these relays.
Tue Jun 23, 2009 10:52 pm
pimp_mobile wrote:Hmmm... so what does the middle relay do then as it hasn't been modfied and it doesn't have a Cat and never has done. There are wires coming out the bottom of the socket so its connected to something(!)
Wiring for a cat is all there, whether it has one or not.
If the relay is fitted, all it will be doing is switching power to the lambda sensor socket under the battery tray.
pimp_mobile
Wed Jun 24, 2009 10:44 am
Cheers Brian...
yeah_mick
Wed Jun 24, 2009 6:40 pm
i also have a stray thing wire comeing off the loom below the throttle body. the end looks like its been stripped as there is no insulation, i earthed it and it done nothing but when connected to a live feed it turned the ignition on :mad:
at the moment its just floating. any ideas on that?
Wed Jun 24, 2009 11:29 pm
There's a spare socket in this area for an emissions control solenoid valve, but without EXACT wire colours, I can't say for sure.
yeah_mick
Tue Jun 30, 2009 3:26 am
when i get back from holiday ill drop you a pm with some more info if thats ok?
