will M52 328I injectors fit into a e30 325i?
325isporttech1
Fri May 15, 2009 8:57 pm
Hi guys i found a site ages ago that said m52 injectors can be put into the 325i as a direct replacment and as such make the injectors silent and makes the engine more efficient, just wondered if anyone has any knowledge of this?
rix313
Fri May 15, 2009 9:32 pm
I'd suspect they do.
Not sure if they'd over fuel though the flow rate might be higher.
Fri May 15, 2009 9:42 pm
They do fit straight in, but the engine will over fuel, they are not silent though trust me!
325isporttech1
Fri May 15, 2009 9:55 pm
lol any other sugestions in the injector department then?
Fri May 15, 2009 10:09 pm
The closest flow rate E36 injectors are from the E36 320i, they give a better atomisation of the fuel but unless yours are shagged I doubt they would be quieter
Reflex
Sat May 16, 2009 12:12 am
what about for a 327 with uprated fuel pump?
There Was A Time Last Year When I Was 17, But I'm 19 Now... And Things Have Changed
http://photos-h.ak.fbcdn.net/photos-ak- ... 778999.jpg
Sat May 16, 2009 12:16 am
Dont quote me on this but I believe the 2.7 builds just use the standard M20B25 injectors, the next flow rate up though are M50B25 injectors
