fse powerboost valve
shane320i
Has anybody used these on a 325i?Are they worth fitting?Only asking because i know of one going very cheap and was gonna give it a go,assuming its gonna make a difference.
craigieeb
iv heard mixed reports about them, some good and some bad, and what i mean by bad is ..............................they can cause your engine to go on fire
M50 Turbo!!!
I shall say no more
shane320i
Gwynleym10
just cut a hole in one of your vacuum pipes, has the same effect! i.e none.
shane320i
Ok,you've convinced me,i'll forget all about it then
Templ8e30
The FSE boost valves only work if you have engine mods and require more fuel. Hence the reason I have one on my 2.7.
They work by increasing the fuel pressure at high engine loads/full throttle, a standard 325i pressure regulator runs @ 2.5 bar at idle increasing with load up to 3 bar at full throttle.
They are fully adjustable and I have mine set up to 2.8 bar @ idle rising to 3.8 bar @ full throttle (enough pressure for around 250 bhp).
Only buy one if your 325i makes more than 200 bhp as the standard injectors at standard pressure are good for around 215bhp.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Gunni
you are wrong Templ8e30
the stock injectors on a 325i run at 3.0bar over the manifold at all times,
i.e the final pressure will always be 3.0bar as the fpr adjusts itself as required to maintain 3.0bar ,.
you see at idle vacuum is 1bar, so only 2bar fp ir required to build 3bar over the manifold,
anyway stock fuel pressure and stock injectors should run out at around 180hp.
shane320i
Right,im all confused now,aside from a bbtb and a green cotton filter and soon a chip,my engine is standard so do i need one or not???
Templ8e30
Stock fuel pressure and injectors were used on the Alpina c2 2.7 and that had around 215 bhp so
Cheers,
Iain T
Cheers,
Iain T
Ant
- Retired Team Member
You do not need the FSE dude, save your Ԛ£Ã”šÃ‚£
you have the BBTB and intake sorted so all you need now is the fuelling sorted properly accross the rev range, chip it and enjoy M8, the FSE will just dump more fuel in when you slam the pedal open, the result will be LESS performance coz she is drowning in fuel
Email FTW
shane320i
K then,cheers mate
