Need a wiring diagram
rs4pro3
I'm looking for a wiring diagram covering the Headlamp wash/wipe function. I'm going to retrofit it onto my U.S. spec car and want to make sure I do all the wiring correctly between the motors, control, unit and wiper stalk
smithy318i
Don't you have a Bentley Manual?
Sorry i don't have any diagrams!
A1BMW325iSport
buy the loom from bmw its easier, cost me Ԛ£29
rs4pro3
I've got an E28 bentley but it dosn't show the headlight wipers. I'd buy the factory harness, but I'm adding just the wipe function and not the wash so I want to relocate the control unit so you can't see it in the engine bay.
smithy318i
Hold on ill ask around!
A1BMW325iSport
haynes manual has the diagram in
smithy318i
Sorry couldnt find one.
rs4pro3
hum, I'll have to check my Haynes. I don't remeber seeing the diagram. Maybe it's only in the ones printed in the UK
ian332isport
If you PM me your e-mail address, i'll send you a copy of the relevant section.rs4pro3 wrote:hum, I'll have to check my Haynes. I don't remeber seeing the diagram. Maybe it's only in the ones printed in the UK
Cheers,
Ian.
The Haynes diagram is fairly accurate, apart from the key says 14 is the main screen wiper, when it's one of the headlamp wipers.
The only wiring for the headlamp washers, is the blue wire to the washer pump from 53c of the headlamp motor with four wires. The washer pump is controlled by a microswitch inside this motor.
The number of times the wiper wipes each time it is triggered is also controlled by reduction gear operated microswitches inside each motor.
The motor are started by a short 12V+ pulse applied to the red wire of the motors (black/yellow in loom), and then are kept running untill the end of their cycle by 12V+ on the black wires (purple/blue in the loom).
The two wires from TS and PS on the wiper control module (16) are not present on cars without intensive cleaning.
rs4pro3
Well my Haynes manual did end up having it
But thanks Ian for emailing it to me. I'd still like to get the BMW factory diagram that describes the functions. My ETM disks only cover U.S. models
