millsy81
Post
Mon Jul 11, 2005 7:54 pm
I have just replaced and upgraded my suspension and also lowered it 30mm .When i step back to look at the finished article the car is lower at the back than the front Is this normal??I also changed my rear beam bushes could this have anything to do with it could anyone please help me before i go crazy
I also have like a shuffling/rubbing sound when turning slowly any ideas????????
thanks danny
rowemeister
Post
Mon Jul 11, 2005 7:58 pm
I have a 60mm front and 40 mm rear set up. I did once try 40/40mm and it was lower @ the rear!!! Really the front needs to be 20mm lower than the rear.
325i Sport with Hartge H27 lump
TW166Y
Post
Mon Jul 11, 2005 8:02 pm
sounds like your rear tyres are catching mate, what rubber do you have on? if its not too big example 18" rims there should be absolutly no catching anywhere on a 30mm drop, depends on how wide your tyres are and offset though, and to the above question regarding does the front look higher than the rear, yes it does mate its perfectly normal, other people tend to drop their beemers around 30-35mm at the rear and go for a 60mm drop at the front, ill show you a picture of mine, ive just installed this spax kit and its a 60mm drop all around, click the link below dude and have a butchers
http://img124.imageshack.us/my.php?imag ... 0024em.jpg
rowemeister
Post
Mon Jul 11, 2005 8:06 pm
Car looks well mate
millsy81
Post
Mon Jul 11, 2005 8:16 pm
Thanks for the help fellas!! i had the rubbing/shuffling noise before lowering it. un sure on what to do about the rear springs may change the rear springs for the older springs and see.dont think it will be the wheels catching on the arches only got 17in alpina reps on!!
How do u place a pic of your car on the web site?
THE CAR LOOKS WELL MATE!![/url]
TW166Y
Post
Mon Jul 11, 2005 9:37 pm
rowemeister wrote:Car looks well mate
nice one matey
TW166Y
Post
Mon Jul 11, 2005 9:39 pm
millsy81 wrote:Thanks for the help fellas!! i had the rubbing/shuffling noise before lowering it. un sure on what to do about the rear springs may change the rear springs for the older springs and see.dont think it will be the wheels catching on the arches only got 17in alpina reps on!!
right what you have to do mate is a get a website like imageshack to host your photo then just paste the link, easy as that mate
Post
Mon Jul 11, 2005 10:51 pm
are u sure mine is dropped 35mm and i can see your point but my is actually still level
TW166Y
TW166Y
Post
Tue Jul 12, 2005 12:59 am
Simon13 wrote:are u sure mine is dropped 35mm and i can see your point but my is actually still level
i dont know then mate, the only thing i can say is you probably have shit hot springs like h&r or something along those lines, which are actually a better made spring altogether so therfore have actually been road tested and had many other tests peformed on them to make them a better fitted spring etc.... ive had 4 e30's now, the one i have at the moment is the lowest ive ever gone (60mm) all of the other e30's ive had were dropped 40mm all round and to be honest Simon i still had a big gap at the front end, even though the car sits perfectly level thats got nothing to do with that 2" horrible peice of blackness up front inbetween the arch'n'tyre
Martinaston
Post
Tue Jul 12, 2005 11:07 am
Check the front plastic inner wheel arch on the inside for signs of contact with the tyre's when on full lock for the rubbing sound.
Normally just above the air duct for the brakes.
TW166Y
Post
Tue Jul 12, 2005 11:33 am
:yeahthat: also if tyre has caught it, it may have dis lodged it a bit and it may have dropped down a little, thats also what happened to me but i just ragged it off
millsy81
Post
Tue Jul 12, 2005 5:54 pm
Thanks fellas for the help have to check it out!!
Has anyone removed their heat shield from under the car if so is it okay to remove??????
thanks again Danny
MJK79
Post
Tue Jul 12, 2005 11:25 pm
Beware the Spax lowering kit, with 60mm drop at the front, on 318i's if you're going to do any track days. After a trackday at Cadwell this year we noticed we had started to shave the sump. I think the M40 four cylinder engine has slightly less ground clearance than the M20 six.
