Heater motor
RedThunder
Fri Dec 19, 2008 10:26 am
Hi Guys,
Had a post here a while ago about my heater blower motor not working, so I sourced a replacement motor and resistor from www.e30partz.com and replaced the two of them - and now it still doesnt work :cry:
Could it be that I got dud parts or could the problem lie elsewhere?
Bit of background, fan stopped working except for speed 4 then I took it out gave it a bit of WD40 and all four speeds started working for a day or two, then it knackered completely.
As far as I know the switch is working, is this the only other possibility? Not sure how to test it
Thanks!
Going insane with the cold :x
fowler
Boost Junkie
Fri Dec 19, 2008 10:30 am
sounds like the varistor in switch is knackered dude slave in 2nd hand switch an see if that solves your woes HTH
EX A-Tech Workshop bitch !!!
gone but not forgotten
Chris-W
Fri Dec 19, 2008 10:31 am
Does the fan run if you apply power directly to it?
RedThunder
Fri Dec 19, 2008 11:46 am
Panic over, got my hands on a voltage tester with a light on it for pittance in the local motor factors and narrowed it down to a blown fuse.
Fuse replaced and now I have glorious heat!! :D
I wasn't even cold but took it out for a spin with the heat on full blast cause I missed it so much!
Now to sort out all the other rust, leaks and crap thats wrong with it :-x
