I have a 320se which had a cracked head , seaching the scapyards trying to find a replacement and come across 520 after an hour taking it off and paying very little for it , I found that the inlet valve guides move .
Can any1 tell me how easy this is to fix and if this head will fit seeing that it is stamped 84 and mine is a 90
inlet valve guildes
You mean the guides move in the head, or the valves have a lot of sideways play in the guides?
Turbo-Brown
- Boost Junkie
You need to take them to a machine shop along with the valves.
They'll press out the old ones, heat up the head, freeze the new guides and fit them.
Then they'll recut the valve seats and reface the valves.
If the guides are really moving in the head, then there won't be any heating and freezing required!Turbo-Brown wrote:
Turbo-Brown
- Boost Junkie
Think if the guides are moving in the head then the head's scrap!
More likely that the valves are loose in the guides
advocate
Thanks for the help , have managed to get me hands on another .
like i said Thanks
like i said Thanks
Karan
yeh i doubt the guides ever move in the head... its the vallve mocing in the guides thats the prob.....Turbo-Brown wrote:Think if the guides are moving in the head then the head's scrap!
Renewing valve guides, refacing valves, grinding and lapping them in and skimming the head is the kind of thing you should have done to any second hand head.
It is false economy to just stick it on.
