Misfing badly BMW 318i
sati
Thu Oct 23, 2008 1:57 pm
i went to start my car after its been sitting for around 6months and it was misfiring really badly , it starts up fine but as soon as you touch the gas it revs up but misfires all the way up to 7,000 rpm , there spark there fuel and compression , can the timing be out? as i changed the colling fan as it was a pain to remove! , can this have messed you the timming?
ill post up a video clip if it helps
sohood
Thu Oct 23, 2008 5:14 pm
is there a spark to every plug?
town325i
Thu Oct 23, 2008 5:23 pm
check that the nuts on the coil are tight
Thu Oct 23, 2008 10:09 pm
Examine the inside of the distributor cap and the rotor arm.
Did you remove the air filter and AFM to give space to change the fan?
sati
Fri Oct 24, 2008 1:04 pm
tryed all didnt make a diffence , turn out to be a bad lead , had a small hole so it wasent getting a powerful spark. now it runs sweet.
sati
Fri Oct 24, 2008 1:29 pm
MOD feel free to Close This Theard.
