abs relays...where???
Guest
any1 know where the abs relays r?still got prob with light comming on,just want 2 check relays,r they in the box nxt 2 the airflow meter,with the slide of top??cheers
Martinaston
The abs unit is self contained, just take the top off
Its more likely one of the wheel sensors has perished
pete69zx
actually tiptoes... i think you are right with that assumption. the old grey matter is starting to function more clearly now! LOL
sure someone will confirm this for sure soon though
Cheers,
Pete.
Cheers,
Pete.
Guest
so can u just undo the screw on the top holding down? the 1 with abs written on?!it could well b sensor ,its just the light sometimes comes on b4 i have even moved.
dazleeds
- old skool raver
from what you said i would give the sensors a good clean my old 325s history book showed that once a year they failed and were cleaned Daz
www.oldskoolfantasy.co.uk
Martinaston
Yeah just take the cover off.
The abs loom connects to the car at the battery terminal and earth point behind headlight (i think, not sure) and three wires to the ignition behind glovebox.
pete69zx
i believe these are the relays your looking for (in a jedi mind trick kind of voice, lol)
please note these are not in situ anymore.
Cheers,
Pete.
Cheers,
Pete.
Guest
could well b mate,r they under that cover with abs written on it,just behind the ns headlight?
pete69zx
yeptiptoes325 wrote:could well b mate,r they under that cover with abs written on it,just behind the ns headlight?
Martinaston
they look like the engine relays
TOURINGDADDY
TOURINGDADDY
Martinaston
have a look at this one it will show what your looking for
http://www.realoem.com/bmw/showparts.do ... g=34&fg=20
ABS relays are under the black plastic cover marked ABS on the ABS unit itself behind the left headlamp.
