Does anyone know why item 10 in the following link
http://www.realoem.com/bmw/showparts.do ... g=62&fg=40
should start buzzing all the time?
To stop it I have removed the connector from it next to the headlight level adjustment. No idea why it has started this all of a sudden. I think it is part of the OBC but that seems to be ok.
Thanks,
Matt.
Buzzing Gong
matcox77
Sjoerd320i
have you changed any setting on your obc lately?
that could be the problem
matcox77
No not changed anything, I don't even know how long it has been buzzing for, it was fine when I parked up on Sunday and when I opened the car last night it was buzzing. When I got in from work tonight it was the same so I have disconnected it until I have time to look at it on Saturday.
It's strange how is has just started.
Matt.
Matt.
Sjoerd320i
sorry mate can't help ya then
hope someone else one here can help you out so you can sort it
cheers Sjoerd
cheers Sjoerd
matcox77
Thanks Sjoerd,
Im sure someone will know what is going on. I may just disconect the power to the OBC for a bit and see if it starts up again ok.
Matt.
Matt.
Widge
Yep thats the OBC gong, it gongs every time it is earthed so check the earths between it and the obc. Otherwise it's probably buggered
This happened to me. I fixed it, but I'm bug***ed if I can remember how!
