Split boot on track rod end
orkboss
I have split the rubber boot that goes over the ball joint on the track rod end where it joins the steering knuckle on th estrut housing. Is this a new track rod end for the mot or can I replace the rubber boot?
jamesroools
just replace the boot, that will get you through the mot
orkboss
I dont think you can obtain the boot on its own. I have ordered another track rod end now.
jamesroools
you can just get the boot, ecp stock them
part no. 612110040
part no. 612110040
orkboss
I am not sure this is the same. I think this is the gator where as I am refering to the rubber boot surrounding the ball joint. But I have a new track rod end now so.
[/img]
Supplier's of bits for kit cars can supply replacement boots.
