Door Locks...
Guest
Post Mon Jun 20, 2005 1:16 pm
Sometimes my passenger door locks by using my key in the drivers side door lock and other itmes it doesn't... Any ideas what's going on? :?
elliot
Post Mon Jun 20, 2005 1:29 pm
open the drivers door, pull off the rubber shroud, get a small terminal screwdriver and push each one of the terminals in carefully.
try this first and report back soldier :D
elliot
Guest
Post Mon Jun 20, 2005 1:58 pm
Rubber shroud? Is this the door lock mechanism you can see when you open the door? :?
elliot
Post Mon Jun 20, 2005 3:17 pm
there should be a rubber cover type thing in the piller between the hinges on your door, pull it off and you will be met with a multi connector.
elliot
Guest
Post Mon Jun 20, 2005 11:16 pm
OK yep, I know the thing. I'll give that a go...
Thanks. :)
