SI board removal
gioris4
Post Sun Jun 19, 2005 10:15 pm
Hi all,
Can I remove completely the SI board from the instrument cluster? Why is it used for, except the service lights?
Should I short-circuit any pins on the instrument board?
thanks,
George
Templ8e30
Post Mon Jun 20, 2005 3:56 pm
Hi George, Yes you can remove the SI board. It sits inside the instrument cluster, remove the cluster and remove the screws holding it together then split the two halves. The board sits in the front half of the cluster, remove 1 screw and carefully remove it.
The SI board powers the instruments and as far as I know several instruments will not work without it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Donnie
Post Mon Jun 20, 2005 7:40 pm
including your rev counter I believe........
*Yo Way Yo* Farewell to the last of the Brunnen G
gioris4
Post Mon Jun 20, 2005 8:36 pm
That's the cluster separated from the SI board
Soooooooo, can I connect any of the circled pins together, to make the instruments work?
The SI board is damaged because of blown batteries and I can't find another to replace it (it's an '84 cluster, without a coding plug). And a complete cluster is a bit expensive here...
smithy318i
Post Mon Jun 20, 2005 10:57 pm
This procedure only works for a certain one, i think the MOTO and not the VDO type.
It's very simple (credit goes to Haber)
Solder a wire link between these two pins.
-------- -x--x-- SI ByePass
You WILL loose the brake wear indicator light and the LED bar, but everything else works fine.
gioris4
Post Tue Jun 21, 2005 4:09 pm
Thanks man. It's a motometer cluster, so I'll give it a try.
A1BMW325iSport
Post Tue Jun 21, 2005 4:21 pm
gioris4 - send me a photo of your SI board i may have one for you.
Matt
