Alpina 15" ET12 fitment question
pegase747
Wed Sep 03, 2008 3:01 pm
Hi to all,
I've just fetched some very nice wheels for my E30, Alpina 15x7 ET12, type 09.
they are the original wheels fitted on E21's Alpina, quite a rare catch.
I heard that the can fit on E30s but would like to have some of your experience...
Do you think they will fit with a -30mm lowered of the car and with 205/55-15 front and back ?
If not then maybe they can fit with 195/60-15.
I've already been to the tyres size calculators like this one :
http://www.rims-n-tires.com/rt_specs.js ... t1=&text2=
but it doesn't tell me much about how big are the front and back wheel wells of the E30...
I am pretty sure they will fit, but if somebody with experience has tried this offset and relatively small size before, I would love to know.
You guys fit 16, 17 even 18 inches wheels on your E30 so I am pretty confident.
Hope you can have an answer for me.
Cheers / Pierre
zimmerbimmer1
BMW Parts Meister
Wed Sep 03, 2008 4:26 pm
The standard ET for 7x15 on an E30 is 24 so there is a 12mm difference I suggest a trial and error fitment.
you may need to extend/roll the arches or fit a spacer
Morat
Wed Sep 03, 2008 4:45 pm
Have I got it backwards or does that mean the wheels will be 12mm further outboard than a standard set?
StuBeeDoo
Wed Sep 03, 2008 5:42 pm
I have a slight body contact issue on the rear with my et13 MiM's.
It's not on the arch lip, but the outside edge of the inner arch, just above the lip.
HTH
Stuart.
StuBeeDoo
Wed Sep 03, 2008 5:43 pm
Morat wrote:does that mean the wheels will be 12mm further outboard than a standard set?
Yep! :thumb: :D
StuBeeDoo
Wed Sep 03, 2008 5:45 pm
zimmerbimmer1 wrote:you may need to extend/roll the arches or fit a spacer
Spacer would make the problem - if there is one - worse.
pegase747
Thu Sep 04, 2008 3:45 pm
You are right, Spacer will make things much worse...
i think the wheel well of the E30 is quite big, but it might actually rub in the inside front fender plastic cover.
Anyone else got any more feedback ??
Cheers / Pierre
1988 Alpina B3 2.7 nbr 224/257
[img]http://i6.photobucket.com/albums/y228/pegase747
stevieallstars
Thu Sep 04, 2008 4:35 pm
this may help explain offset
zimmerbimmer1
BMW Parts Meister
Thu Sep 04, 2008 4:52 pm
so to confirm then for my peace of mind the ET on bmw's is negative offset
StuBeeDoo
Thu Sep 04, 2008 5:04 pm
zimmerbimmer1 wrote:so to confirm then for my peace of mind the ET on bmw's is negative offset
No, it's positive.
