Hard to start when 'warm': '89 325i Touring
Beowolf325iT
Post Mon Jun 13, 2005 5:29 pm
Greetings again from Canada...
I've had this problem on/off for months...now the past week the 'warm start' issue is back. It's rather odd...fires right away when cold, then if you drive for say 1/2 hour then stop, leave for 1/2 hour it will be 'difficult' to start (engine turns over for 10-15 sec's then starts just b/f it sounds like it might just die...) I've heard bad 'coolant temp sensor' from a number of sources now.....
This 'intermittent' issue continues to baffles me...
JA
:roll:
johnono
Post Mon Jun 13, 2005 6:29 pm
just as a guess (not 100% sure this is accurate)
blue temp sensor
brown sensor
new coolant and flush
icv cleaned or replaced
air intake hose replaced
afm recon.
fuel rail line checked (dodgy jubilee clip)
not sure if is what u need, but it couldnԚ´t hurt :)
Guest
Post Mon Jun 13, 2005 6:31 pm
What are the spark plugs looking like? If they are sooted then it is an over fueling issue. Had the economy gone bad?
I had something like this but it was a gradual decline until it, an auto, started stalling at traffic lights. My problem was a dead fuel pressure regulator.
Have a bit of a search around for a check list, as i think my problem can be quite rare, but our cars are late teens so rubbery diaphams etc can and will perish.
Here is a brief check list of cause and effect, choose engine problems from the side bar,
http://www.unixnerd.demon.co.uk/bmw.html
Beowolf325iT
Post Mon Jun 13, 2005 6:48 pm
jezza wrote:What are the spark plugs looking like? If they are sooted then it is an over fueling issue. Had the economy gone bad?
Thanks for the reply(s). I'll pull out a plug to check out what's happening. I did recently have the intake manifold gasket(s) replaced as they were 'seriously deteriorated', leading to a very rich mixture. Could have fouled the plugs over time. Fuel economy has been gradually declining as well.
Many Thx,
Jeff
1989 5spd 325iT
Beowolf325iT
Post Tue Jun 14, 2005 2:44 am
That tune-up/check-up, as you say johnono, couldn't hurt as well....
Cheers m8
johnono wrote:just as a guess (not 100% sure this is accurate)
blue temp sensor
brown sensor
afm recon.
1989 5spd 325iT
320Touring
Post Tue Jun 14, 2005 10:22 am
blue temp sensor
brown sensor
afm recon.
:yeahthat: a tuneup and plug replacement makes some difference
orkboss
Post Wed Jun 15, 2005 1:37 pm
Of course the first thing you should do is replace the air filter as a clogged air filter would give the problem of being hard to start when hot.
