Smoked headlights DIY or new?
scurran83
Thu Jul 10, 2008 2:06 pm
Considering getting smoked headlights just wondering whats the best way to get or do them?
SPADGE
Thu Jul 10, 2008 2:09 pm
Hyperion
Thu Jul 10, 2008 2:11 pm
I suppose if you would like to have the satisfaction of knowing you "did it" yourself, i would go the DIY route.
But if you have a fear of cocking up the whole thing, then buy new.
PS: some zoners will sell you a pair of DIY smoked ones, just another option.
cheers
psychochild187
Thu Jul 10, 2008 3:17 pm
that and if you dont want the fear of breaking originals then go for DIY
Aragorn
Thu Jul 10, 2008 3:45 pm
the only concern i'd have is that quite often the aftermarket lamps have pretty bad quality projectors in them, which may mean DIY is a better approach
pony2
Thu Jul 10, 2008 3:52 pm
Getting the glass of using a heat gun is not much fun, danger of burns and little bits of glass flying around. I gave up and stuck mine back on the car. It can be done, just not a nice job.
psychochild187
Thu Jul 10, 2008 4:49 pm
i got the original hella lights
but the things come with such rubbish plastic adjuster bits they break and remaking the adjusters out of bits n pieces you find off the old light sis annoying too.
stonesie
Thu Jul 10, 2008 5:18 pm
I had to buy a heatgun to do mine so while i was in B&Q i bought some thermal gloves too... that was a few quid well spent as you need to get them quite hot.
Mine took about a day to do and i played it safe by buying a 2nd set of headlamps from Eko on here, mine were held together with tie wraps 8O no wonder they wobbled about a bit, and i managed to make a good set out of the pair.
If i do it again i will do things differently, especially with the cross-haire's.
