how tight should my....
craigieeb
Post Sun Jun 12, 2005 9:40 pm
camshaft be??
iv just fitted a cam to the head, and it seemed to go in pretty good till the last bit it just seems too tight, it wouldnt push all the way in by hand so i had to tap it with a rubber mallet a couple of times, now it wont turn at all,
so should it be this tight? or am i just being parhanoied coz im sure the last cam wasnt as stiff as this one :?
smithy318i
Post Sun Jun 12, 2005 9:54 pm
Is it NEW?
Does it have that brown sh!t on the cams?
it shouldn't be jammed solid!
try rotating it a few times.
Turbo-Brown
Boost Junkie
Post Sun Jun 12, 2005 10:15 pm
If you're talking about the cam in a bare head with no rockers etc. then it should glide in on the lube you've put in all around the bearings and should turn easily and smoothly with no tight spots.
If it doesn't then I'd suspect that something's amiss :(
craigieeb
Post Sun Jun 12, 2005 10:16 pm
no it's not a NEW cam it's a second hand one,
it's had a goood clean before it was put in and so was the head, it's weird it was nicely lubed before assemble and there is nothing else on the head just the cam, iv allready took it out and there were no markes of any kind anywhere, put it back in and it's exactly the same
Post Sun Jun 12, 2005 11:21 pm
Has the head ever been warped and skimmed?
Skimming the head flattens the head face, but it doesn't line up the cam bearings again.
craigieeb
Post Sun Jun 12, 2005 11:38 pm
i dont know if it's ever been warped, but iv just got the head back from being ported and skimmed, i'll give it a good looking at in the daylight and see if i can see if anything is a miss
craigieeb
Post Mon Jun 13, 2005 4:09 pm
sorted, i had to bray it out of the head, i gave it a gooood looking over nothing a miss, so i lubed it up again and i turned it in insted of hitting it with a mallet and it seems to be turning nicely, so i recon all is good :cool:
320Touring
Post Tue Jun 14, 2005 8:32 am
Job's a goodun mate!
looks like your luck is turning for the better :D
