Power hood inop
kregcab
Post Sun Jun 12, 2005 7:07 pm
Can anybody direct me in the right direction on this please, my power is not working the car is a E30 318i 1991 ANY IDEAS WHERE TO START.
CHEERS
dazleeds
old skool raver
old skool raver
Post Sun Jun 12, 2005 7:11 pm
first stop check fuses and relay not sure which relay but should say in the dodgy old haynes book gdluck mate Daz
www.oldskoolfantasy.co.uk
orangecurry
Post Sun Jun 12, 2005 10:14 pm
1) be very VERY careful
2) open the boot and disengage the 2 motors - one is fairly central and the other main one is on the right - if you want, pull out (carefully) the trim/lining/carpet etc to make it easier
3) open the top CAREFULLY SLOWLEY by hand; push the very front up, then lift the back section of the roof, then the 'lid', whilst standing at the drivers side - you should be able to see the mechanism now
there's a main rod running front-rear from the hood frame to the body via a funny shaped 'gear' which rotates in a horizontal plane; is this torn out?
DaveD
E30Zone Wiki Specialist
Post Mon Jun 13, 2005 3:18 pm
There have been soooooooo many threads on this you ought to go back and look,,,but first of all check if there is power
