towing my 325
325_track_day
Fri Jun 10, 2005 7:55 pm
got a 325 manual with lsd track day car
was gonna tow it to track days on a dolly will this be ok for the box etc
TOURINGDADDY
Fri Jun 10, 2005 9:06 pm
Yes it is ok but if ur still not happy then lift the rear wheels
325_track_day
Fri Jun 10, 2005 10:26 pm
im happy if its ok
Jesus325iTouring
Frog freak !
Frog freak !
Fri Jun 10, 2005 11:59 pm
I've towed just about everything you can tow with my 325 and have never had a problem,the only thing I would complain about is having to change gear to much,the E30 gearbox isn't really designed for towing in my opinion,but as long as you don't mind changing gear to much,you won't get any problems.
As for your track car with LSD,this should make no difference,it's only auto box cars you shouldn't tow.
320Touring
Sat Jun 11, 2005 1:20 pm
yeah towing with a dolly should be fine-wont do any damage :cool:
could also use a towing bar (Ԛ£30) instead and have 4 wheels on the ground...
bullitt
Sat Jun 11, 2005 1:38 pm
320Touring wrote: use a towing bar (Ԛ£30) instead and have 4 wheels on the ground...
And someone to steer it!! :lol:
Ant
Retired Team Member
Retired Team Member
Sat Jun 11, 2005 2:54 pm
Towing a car equipeed with an LSD is a big NO, by the time you get where you're going the clutch pack will be scrap in the diff dude
Please dont do it !
320Touring
Sat Jun 11, 2005 2:56 pm
ant wrote:Towing a car equipeed with an LSD is a big NO, by the time you get where you're going the clutch pack will be scrap in the diff dude
Please dont do it !
could put the rear wheels on the dolly and leave the steering lock on?
