lowered touring
Cloggy Saint
Post Tue Aug 08, 2006 6:32 pm
Cheers for all the advice people, i'll see how things develop before panicking too much!
toby
Post Fri Aug 11, 2006 10:53 am
don't panic
you can buy a set of lowering springs specifically for a touring from gsf for about £45 and get them sent over to you. Let me know if you need some help finding new springs
oze30
Post Fri Aug 11, 2006 12:10 pm
if the higher spring is on the drivers side.. id leave it. Its a common thing to do in 4x4's.. so why would it be different to a car?. When I checked my new(thanks quaser) springs, they were uneven in length (just slightly but still.. then i just put the taller spring to the drivers side.
cougar
Post Fri Aug 11, 2006 12:16 pm
Jos wrote:no camber adjustment on the rear beam, I have an adjustable beam I made, will stick pics up of it, corrects about 5 degrees -ve at max setting I think.
was it hard to make?
Jos
Post Fri Aug 11, 2006 1:00 pm
Not really if you have the right tools, well tool.. you will need a mill to do it basically.
Get a length of steel flat bar 50mm x 10mm x whatever length and machine a channel the same width as the diameter of the e34 eccentric bolts(38mm I think it was), I machined to a depth of 7mm, leaving 3mm of base on it. Then mark it every 50mm along the bar and mill through on 1/2" and ream out towards the raised areas. Mount on the subframe and weld all the way round. The hardest bit was milling out the existing holes on the frame, I used a dremel to do it, not fast but was the only thing I could use to get in there with, a gas axe would do it ok too but would need finished off with the dremel anyway. Mine is painted with Vactan and coated with Dinitrol, missed a couple of bits as you can see :p
Bolt PN 33321095102
Nut PN 33326751446
Washer PN 33321092310
The idea was taken from http://e30m3performance.com/installs/in ... /index.htm
The part numbers they have listed are wrong though, check it off against realoem, the ones I have listed are the correct parts.
Subframe1
Subframe2
Subframe3
Subframe4
Subframe5
'94 e36 tree climber
jamesc
Post Fri Aug 11, 2006 8:43 pm
This is my car with the 60/40 H&R kit fitted.......
James
ad318i
Post Fri Aug 11, 2006 9:01 pm
can see your in the dam.....
all the bloody bikes about lol i remember everywhere you turned there another bike was there!!!
car looks b good neway hope you get the camber sorted
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
Cloggy Saint
Post Thu Aug 24, 2006 3:35 pm
jamesc wrote:This is my car with the 60/40 H&R kit fitted.......
James
Sorry to regurgitate an old topic, but i've been away for a couple of weeks. Jamesc, if that's a 40mm drop at the rear then I'm certain I either have saloon springs or something lower than 40mm....
jamesc
Post Thu Aug 24, 2006 7:44 pm
That was a couple of weeks after fitting, it as dropped a little more but not much. This is 2 up after a 400 mile drive across Europe :D
James
Cloggy Saint
Post Thu Aug 24, 2006 11:37 pm
Your front looks just about the same as mine and the back looks higher. I'm sure i don't have 40/40.
