I will have a look on Saturday (my next free day) for the wires etc.willnz wrote:Does you car have the overhead check panel?
I also want you to give me the wire colours (exact!) coming into the rectangular C101 plug from the body side. Make sure you get the pin numbers right. You will find them on the plug face but will need good eyes to make them out! I just want to check that the body loom wiring is the same for the injected version as for the carb version as i dont have a carb version wiring diagram.
Another thing you will have to do to convert the motor to an injection one is change the fuel tank for one which has the swirl chamber around the fuel pump. The carb tank doesn't have one.
Also mate, I am running a 55L non swirl chamber tank on my M42 (in the avatar) and am having no probs what so ever. I will prob need an "in-tank" pump and sender and the wiring for it but will have to check both of my cars and see if the 85 has the standard loom in place.
I had already thought of this but think I will be ok.
I will see how I get on with that.
