driver door mirror replacement
exup
Boost Junkie
Thu Dec 27, 2007 2:08 pm
Hi
, Happy new year all
my drivers door mirror needs replacing as its just fallen off !
i ve got a spare diff coloured mirror but only really want to swap the glass . electric motor s etc over ,
the existing ones broken the plastic geared rack and little retaining pins on it , so the glass is dropped out
is there a trick to remove the glass from the good door mirror with out breaking it or the plastic gears etc ?? and re fitting it to the over coloured mirror ?
shedrool83
Thu Dec 27, 2007 2:20 pm
To remove the glass insert a thin screw driver in the hole on the underside of the mirror and turn the retaining clip.
HTH
goosiegander
Zonegoose
Thu Dec 27, 2007 2:24 pm
its a sliding clip at the base of the gear mount you describe, normally you can slide the clip with a small flathead screwdriver through the small hole at the centre base of the wingmirror, though, as brianmooore will tell you -its easier to angle the mirror as far up as possible so you can get at the retaining clip looking at it from the base of the frame rather than the hole -the clip slides transversely, hope that helps :D
exup
Boost Junkie
Thu Dec 27, 2007 2:25 pm
Thanks all
will go and try it
exup
Boost Junkie
Thu Dec 27, 2007 3:46 pm
All done
many thanks
Thu Dec 27, 2007 8:04 pm
Make double sure that the locking ring has locked in place! Many have had their nice new mirror glass fall off five miles up the road.
gra325i
Thu Dec 27, 2007 10:01 pm
lol me being one of those people in the past :mad:
tailoutcharlie
Thu Dec 27, 2007 10:04 pm
+1 here :o:
Chris
