As I'm here, any thoughts on the problem would be appreciated
At speeds under about 5mph one of the sensors seems to think a wheel is locked, which fires the ABS. This is annoying and lengthens the braking distance but it also causes all sorts of worrying noises. Sometimes the ABS warning light comes on (usually only when the car is cold oddly) and if it does, the problem goes away. Although this obviously means I have no ABS, the car is a lot nicer (and over all safer) to drive like this than it is with the ABS going loopy.
I'll get the ABS checked but in the mean time, how do I deactivate it?
Thoughts appreciated please E30 gurus
