got my touring today. feels a tad underpowered.
kam-325i
- Contact:
0 261 200 380 is the part number for a 325i ECU
So is
0 261 200 073
0 261 200 081
0 261 200 164
0 261 200 173
0 261 200 380
0 261 200 402
0 261 200 403
So is
0 261 200 073
0 261 200 081
0 261 200 164
0 261 200 173
0 261 200 380
0 261 200 402
0 261 200 403
- Brianmoooore
Don't modify a faulty engine. Get it running perfectly in standard form, then modify.daveyw wrote: i'll get a chip fitted asap and see how it goes then.
just a thought, but is it possible that its the airfilter causing the problem? its had a k&n cone filter fitted by the previous owner. my local (ish) rolling road place reckons they're crap and you get better performance with the standard airbox. anyone any thoughts on this? i was wondering if it's getting too much air which is probably warm air anyway as theres no air feed pipe thingmejigger going to it. its not the greatest fit either. you can easily pull it off by hand no matter how much you tighten it. thanks again guys. you've all been great!
StuBeeDoo
'Tis true! Mine had a K&N on when I bought it. I couldn't put my finger on it, but it just didn't run "right". Took the K&N off and reverted to standard and it was fine.daveyw wrote:its had a k&n cone filter fitted by the previous owner. my local (ish) rolling road place reckons they're crap and you get better performance with the standard airbox.
I'm not saying it's the whole answer to your problem(s), but it seems to be the obvious starting point.
thats good to know! and another thing (ffs i hear you say!) the fuel pump sounds quite noisy. possibly on its way out and not giving enough fuel?essbee wrote:'Tis true! Mine had a K&N on when I bought it. I couldn't put my finger on it, but it just didn't run "right". Took the K&N off and reverted to standard and it was fine.daveyw wrote:its had a k&n cone filter fitted by the previous owner. my local (ish) rolling road place reckons they're crap and you get better performance with the standard airbox.
