2.7 eta
daveo
Sat Apr 14, 2007 3:26 pm
what is the differince between eta motor and the super eta.
dave
Templ8e30
Sat Apr 14, 2007 9:24 pm
Iirc the eta engine uses flat top pistons and a '200' type head with small ports and valves. The super eta uses 325i type pistons/head/valves.
I don't think we got the super eta here in the uk.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Hadrian
Sun Apr 15, 2007 10:49 am
Super ETA has the 885 (325i) head but I think it has less camshaft bearings meaning it itsn't designed for as high RPMs as the normal 885
--alpina--
Sun Apr 15, 2007 9:10 pm
the ETA from 81-85 has 11.1 comp ration therefore the pistons are slightly (domed) and has very slight cuts for the valves to meet, from 85 onwards the comp ration is 10.1 and the pistons dish in (concaved) and used a standard 325 head as with the earlier ETA it has lesser cam journal bearings and ports (inlet/outlet) stupidly small!
j
daveo
Mon Apr 16, 2007 7:25 pm
thanks for your input.
I have the later eta engine with concaved pistons is it possible to just bolt a 325 head on to it or will i have to use a 320 or 323 head.
Dave
--alpina--
Mon Apr 16, 2007 7:45 pm
For the Later ETA engine i would use an 885 casting (325) head, so i would change the camshaft to a highlift (peformance) i wouldnt use a a 320/323 head, ive tried it and i just got erraticle idling... if you have an 885 or going to get hold of one make sure you skim the head and use new head bolts...
use the 325 loom setup and your sorted, sweet as my pedegries!!
j
daveo
Tue Apr 17, 2007 9:50 am
Ive just looked at the head that was fitted to my 525e engine and its a type 200 so will a 885 casting head still bolt on or not.
Dave
--alpina--
Tue Apr 17, 2007 10:04 am
Yes the 885 will bolt on, get one and bolt it!!
j
daveo
Tue Apr 17, 2007 10:12 am
j thanks for your help.
Dave.
**BANNED**
Tue Apr 17, 2007 1:38 pm
It is possible to modify the eta head to take a proper cam.The expert at this is temple30,you may find that it is cheaper to modify and recon your existing head rather than buying and crack testing aand reconditioning a 325 head.If you decide not to use the eta head,can I have first refusal,please?
