Bonnet Release
The other day i was opening the bonnet and the bonnet release cable snapped! Does anybody know how i can open the bonnet so i can replace the cable? Can i just go underneath the car and find the bonnet release catch and release it with my hands or is there another way Thanks
- Brianmoooore
There's a slot for a screwdriver behind the LH headlamp grill.
ive tried putting a screwdriver there but it seems 2 do nothing. the catch seems to be in the center of the grill, ive been under the car and i can see the release cable ive tried to pull it but there is only so much i can pull. any other suggestions?
Patience or Dynamite
That's the only way that it'll ever open again. You should be able to access the release mechanism. If you have got a friend with an e30 look at theirs to see how it works with the bonnet open. This way you will identify what needs moving and what doesn't,
Otherwise post for more help and maybe a zoner in the area can help you out.
[/quote]
bottlecapE30
that was Moon Unit Zappa and the other is dweezl it has got to suck growing up with a name like thatChris-W wrote:As Brian says, it's begind the N/S headlight grille, between the kidneys and the main beam unit (one of Zappa's kids?).
Get a torch and you'll see the hole in the grille, 2nd one down I think.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
