Gearbox Oil Diff Oil Engine Oil Recommendations please (M20)
- alpinac227
- Contact:
Have an E30 ALPINA C2 2.7 based on a 325i M20 with about 65,000 miles and want to change all oils Gearbox Diff Engine PAS recommendations please..? Gearbox changes are a bit stiff, wondering maybe incorrect oil, car has been stood sometime would this be possible cause.
FlappySocks
- Contact:
There are lots of recommendations if you search for it. Depends how stiff your change is. Second gear can sometimes be a problem, and reading on the forum, ATF fluid is an option.
Stuart.
Stuart.
stuartgallafant
Project_E30
Stuart do you know what quanities are needed for the gearbox and diff?
stuartgallafant
Motronic to Megasquirt Plug and Play Guide
