M42B18 - Lumpy Id
Scottlaw
Post Mon Jun 08, 2026 8:31 pm
Hello Zoners
Tearing my hair out with this one. Swapped my engine from a m40 to a m42.
All was going well and driving fine but then the car started to idle roughly, it almost splutters a tiny bit. It’s making the car shake a little with idle, but when it’s moving it’s great.
I have replaced:
- ICV (twice)
- intake boot
- vacuum connector thing
- spark plugs
Also ran multiple smoke tests with no results.
Any ideas would be appreciated!
Scott
Post Wed Jun 10, 2026 12:02 am
Has it got a standard ECU chip? 318is engines are very fickle when it comes to this! Also worth checking basics such as good engine-to-body earth strap, and do a compression test to ensure all cylinders have about the same reading.
Scottlaw
Post Wed Jun 10, 2026 7:49 pm
Standard yes. Would a chip from you potentially improve it?
