Bonnet Insulation
mickes
Mon Aug 01, 2022 3:49 pm
I am in the process of replacing my bonnet Insulation but finding it almost impossible to get the old adhesive off of the underside of the bonnet. So far I have tried soaking with water, panel wipe, alcohol, meths and paraffin but none have worked, obviously can't use thinners.
Has anyone done this job before and had more success. I don't really want to stick the new insulation over the old adhesive.
Mon Aug 01, 2022 4:18 pm
There are more than one way to do this but I used WD40, Let it soak a bit and it will come away with a bit of help.
Yes it did work !!
Sorry for this..............cover your engine bay first lol.
Corasdad
Mon Aug 01, 2022 5:01 pm
Caramel wheel might work
Cloggy Saint
Mon Aug 01, 2022 6:15 pm
Save yourself a lot of effort and don't bother, just remove the dry flaky foam. I stuck new foam on old adhesive about 12 years ago and it's still holding firm.
BenHar
Mon Aug 01, 2022 6:49 pm
Brake cleaner has been recommended on here in the past.
Ben
Dlb26
Mon Aug 01, 2022 8:58 pm
I've recently done mine and found isopropyl/isopropanol alcohol to work really well with a foam eater used to desolve expanding foam.
See midway and after photos. You can see the two side panels are back to painted metal.
twright
Tue Aug 02, 2022 1:01 am
I agree with the poster above that says you don't have to get it ALL off. I used sandpaper to remove the big lumpy stuff and didn't touch the paint.
The new insulation stuck on just fine.
Corasdad
Tue Aug 02, 2022 2:25 pm
Looks good
BristolE30
Wed Aug 03, 2022 10:37 pm
Agreed, don’t bother removing it
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
Contours
Thu Aug 04, 2022 11:59 am
If you want to get it off, use white spirit. It will just disintegrate and fall off. Makes it a lot easier to fit the new foam
chatstar123
Thu Aug 04, 2022 8:38 pm
I second that. White spirit got all the adhesive of really easily
