Hi guys
Was wondering if anyone can help..recently on my e30 325i cab Thers a rather load clunking noise coming from rear and feels likes something hitting the body underneath from rear..only happens if I drive it hard..if I set of normally without the hard revs Thers nothing?any ideas ?i personally think it's something to do with propshaft?thers no whines or anything coming from diff..some people suggested check the driveshafts etc may be loose?
Load clunking noise from rear e30 325i cab
Gert_8
Have you looked at the exhaust hangers? Might be that simple.
driveshafts,
i explored all options, exhaust, handbrake shoes shit hitting...
i pulled my shafts out yday and was met with this....
took a while but cleaned it out with some cotton buds and a shit load of brake cleaner swished about...
had metal particles i believe and shit inside...
packed it out fully with grease and hoping it does the job...
Grrrmachine
- E30 Zone Wiki / Team Member
A quick test is to check that all four diff bolts are on tightly. It's not unknown for one to work loose over time.
If they're all on tight, check the things others have said, and also check if your rear beam bushes have ever been done. If not, they're long overdue.
