Anyone know where the spring goes for this oil filter housing??
When i bought the unit and it came with a spring but i can work out where it goes.
Can't find much online about it
e28 oil filter housing spring??
mincedbeef
Yeah it doesn't show a spring but it came with it so i'm a bit confused
mincedbeef
Anyone ever seen it??
mincedbeef
No picture, its at home.
It just came with the housing slid over the long bolt that holds the canister on.
Fitted a new filter and if the spring goes back over the bolt like it was but it seems pointless as it just slides up and down the long bolt.
Just thought it must have a purpose
- Brianmoooore
Normal arrangement in a replaceable element type filter is for a spring to sit on the centre bolt in the bottom of the can, with a large top hat washer on top of it. This seals the inside of the filter from the outside, and pushes the filter against the top of the housing.
mincedbeef
Ok cheers chaps
I'll have a look for 1
