Do you know if a 525 engine is the same as a 325? i.e. will it drop straight in?
Regards
Chris
Will a 1992 525i engine fit into a 1990 325i?
- stevetigger
the 525 is 24 valve! It will fit but its hard work, there different engines!
M20 325
M50 525
M20 325
M50 525
- stevetigger
About 89bigdek wrote:unless its not the 24 valve then its the same.
not sure which year thay changed
- Brianmoooore
M20 engine from 525 is basically the same as E30 M20, but a few things bolted around the outside are different.
Shouldn't be any problem swapping a 6 pot for a 6 pot, but you will need one or two things extra to swap for a 4 pot.
- stevetigger
But he asked if a 1992 525 engine would fit!Brianmoooore wrote:M20 engine from 525 is basically the same as E30 M20, but a few things bolted around the outside are different.
Zayyan
- Contact:
What? Where?stevetigger wrote:But he asked if a 1992 525 engine would fit!Brianmoooore wrote:M20 engine from 525 is basically the same as E30 M20, but a few things bolted around the outside are different.
- stevetigger
Thread title!Zayyan wrote:What? Where?stevetigger wrote:But he asked if a 1992 525 engine would fit!Brianmoooore wrote:M20 engine from 525 is basically the same as E30 M20, but a few things bolted around the outside are different.
- Brianmoooore
So he did - in the thread title.stevetigger wrote: But he asked if a 1992 525 engine would fit!
Answer is yes, with a lot of additional parts and hard work - but the results are worth it.
Been discussed many,many times in the "engine swaps" forum.
whats the difference with the 525 m30 "big six" ive read about? Goddam it theres too many variations for each model!
what 525 bottom end would fit a 325i? I know about the 525e 2.7 route and so far have been unsuccessful in finding one so im trying to find a regular bottom end.
ive found a P plate 525, but i would rather know what im looking for.
- Brianmoooore
P plate 525 will be a M50 with vanos variable valve timing. Very nice conversion for an E30. That's what I've got in one of mine.
Not sure without checking if this will have the EWS immobiliser system.If it has, get the EWS module and matching ECU, and the key and column pickup coil.
