Blue temp sensor location - 316i
Kamatari
Sun Feb 09, 2014 11:48 am
Hey guys, probably a silly question but can anyone confirm the location of the blue temp sensor on a 316i?
I thnk its under the air intake pipe on the engine in a slightly awkward small gap (not very technical heh) but just hoping someone can confirm it for me?
TPS
Sun Feb 09, 2014 12:18 pm
If its an M40 (I'm assuming that, as its a 316i), the CTS is under the Inlet manifold, to the right of the Brown Sensor. Its a pain to get at!
Kamatari
Sun Feb 09, 2014 12:27 pm
think that might be the one im looking at although didnt see the brown sensor (will take another look now)
Im assuming theres a small gap to get through for the sensor?
TPS
Sun Feb 09, 2014 12:36 pm
Not sure, I took the top half of the inlet to get at mine.
Kamatari
Sun Feb 09, 2014 12:42 pm
Here are some pics of what im looking at:
Or am i way out?
Grrrmachine
E30 Zone Wiki / Team Member
Sun Feb 09, 2014 12:54 pm
Blue plug = blue temp sensor. Good luck getting that out :D
Kamatari
Sun Feb 09, 2014 12:58 pm
just wanted to make sure :) incase there was any other blue plugs on the car.... dont think im going to enjoy this then heh
TPS
Sun Feb 09, 2014 1:26 pm
Thats the one, to the left, is the Brown Sender.
Grrrmachine
Sun Feb 09, 2014 1:27 pm
To be fair, is there any reason you need to access it? Are you certain it needs replacing?
Kamatari
Sun Feb 09, 2014 2:06 pm
not 100% certain apart from what ive been told and read which is to do with the cold start.....too late now as i removed it which wasnt too bad although it is now raining quite heavily and i was just coming to put in the new one :(
Sun Feb 09, 2014 2:08 pm
TPS wrote:Not sure, I took the top half of the inlet to get at mine.
That's the way BMW intended and why they made the top bit so easy to remove.
TPS
Sun Feb 09, 2014 2:18 pm
I have to say Brian, I totally agree, they're very easy to remove, I wish the M20s were as good!
Billwill
Tue Feb 11, 2014 12:21 pm
Kamatari wrote:not 100% certain apart from what ive been told and read which is to do with the cold start.....too late now as i removed it which wasnt too bad although it is now raining quite heavily and i was just coming to put in the new one :(
You should have left it in place and measured the resistance at the pins on the ECU connector inside the cabin. The Wiki gives you the pinouts of the ECU and the resistance values you expect.
This method tests that there is not a wiring problem going from the Blue Sensor to the ECU. :wink:
skippye36
Tue Feb 11, 2014 10:47 pm
You can get it out and in with a long extension, wobble joint and a lot of manual dexterity lol
