Bmw e30 51mm Shorter shocks
christophsbmw
Sat Oct 06, 2012 2:25 pm
Ok im looking into making an air ride kit for my e30. The one problem im having is finding some shorter 51mm shocks. When i mean short i want to be able to cut the strut towet to fit them.
If not i was going to make a hole new strut and weld it to the hub and add a reinforcing tube.
Jozi
Sat Oct 06, 2012 6:09 pm
Audi 80 I think had shorter struts
handpaper
Sat Oct 06, 2012 6:49 pm
MkII inserts are, I believe, 51mm. Used by one company to make shorter e30 coilovers.
christophsbmw
Sat Oct 06, 2012 7:42 pm
handpaper wrote:MkII inserts are, I believe, 51mm. Used by one company to make shorter e30 coilovers.
Ok cool i have some mates with mk2 golfs will check it out.
Kos
Sat Oct 06, 2012 10:04 pm
sounds like you are going to destroy your suspension if you are going make whole new strut.
best thing to do the is use 45mm struts and use a bilstein instert.
www.pukardesigns.com
IG Pukar.Designs
