Alpina C2 / B3 brake pad options - 296mm x 25mm
Gussy
Thu Jul 30, 2009 9:51 am
Right, I'll probably need to replace the front pads on the Alpina in the next few months. It has the larger Alpina brake upgrade.
However, I presume Alpina would charge a left nad for the privilege of selling me a set (if they're still available?) but I've read a few times elsewhere that the Merc 2.3 16 190E cosworth / W124 300D pads fit - but with 2mm shaved off.
Has anyone else got any other info on this?
Ta.
Thu Jul 30, 2009 9:58 am
Are they really 296mm diameter? I thought they were more like 280, if its the merc callipers and carriers that are used then the pads should slot straight in
Thu Jul 30, 2009 10:47 am
the calipers are W124 300E/190E cosworth. Not 300D!
Pagid,ferrodo seem to be the main companys for them. I've got a set of pagid road pads, and ferrodo DS2500 for track work on my setup.
No shaving required they fit straight on out the box
Gussy
Thu Jul 30, 2009 3:10 pm
That's great Simon, thanks for the advice, I thought it was weird that the diesel would have the same calipers / pads as the 190E cosworth alright!
Where did you happen to buy your pads? Do you have a rough price?
Thanks again :D
Thu Jul 30, 2009 5:21 pm
GSF for the pagids stock road pad £28 8) bmw want around £160!
the ferrodo DS2500 where from europerformance.co.uk for around £100 posted in the UK. - These need heat to work they are crap from cold
Gussy
Fri Jul 31, 2009 12:35 am
Excellent, thanks for that Simon. :D
bigbhpwannabe
Fri Jul 31, 2009 11:48 am
Simon13 wrote:the calipers are W124 300E/190E cosworth. Not 300D!
i take it that these dont just bolt onto normal e30 hubs or everyone would be doin cheap brake upgrades ? gary
325i 4door turbo sleeper -
big turb
e36 carbonfibre wietech strutbrace for sale . 07919173179
Fri Jul 31, 2009 2:13 pm
You need a nice adaptor plate Gary :)
Will you be at Santa pod this year?
bigbhpwannabe
Fri Jul 31, 2009 2:56 pm
DanThe wrote:You need a nice adaptor plate Gary :)
im gonna try , my project started the other day so could be :)
are u gonna come ?
big turb
Fri Jul 31, 2009 7:25 pm
correct you need the custom caliper carrier. As its a girling setup its a cast job like the calipers so looks factory. Not something which could be replicated easily, i've looked into that in the past
Fri Jul 31, 2009 7:59 pm
Sure will, keep an eye out for my black pre facelift :)
