wassup peeps, my 87 327 is sitting at the garage after changing the afm and now there's no fuel coming in, mechanic is saying i need a new pump but i don't wanna buy one if it's not gonna fix the problem.
do you guys know if there might be any other reasons why the fuel ain't coming in?
bless
325i fuel problems
- **BANNED**
Electricity passes from the fusebox via fuse 11 to the fuel pump relay(the orange one).Then goes on to the fuel pump.So if fuse 11 has blown,the fuelpump will not work.Likewise,if the fuelpump relay has blown,the fuel pump will not work.Also,you often find that immobilisers are wired into the fuelpump feed and these can cause problems as well.
Youth is wasted on the young.
